 [ 6 posts ]
Fri Mar 11, 2011 7:10 pm
so just now getting to play with the cyber commander and einsteins and just realized my cyber commander does not fit onto my camera?? sony A900? did i order the wrong one? i dont remember getting the option to choose what camera model i was using? what are my options now?
also, i have a sony F58 hotshoe flash and it has a built optic trigger, but cant seem to get the einsteins to trigger the hotshoe?
Fri Mar 11, 2011 9:51 pm
Flashzebra.com has the adapters you need. Sony uses a proprietary shoe carried over from minolta, and since they are the only ones with that design, many manufacturers do not make direct fit components. The adapter is about $15. The speedlite has an optical trigger that can be activated via aproprietary sequence from a TTL master, but not a regular flash. Flashzebra has optical triggers as well as adapters for our recievers (but power cannot be adjusted).
Sat Mar 19, 2011 9:46 pm
So if I purchase a package, I won't be able to control output with my a900 Sony?
I'm looking for some studio lights, but I want full control. Wireless
Sun Mar 20, 2011 8:22 am
As with any quality remote system, you will need an inexpensive adapter to allow the remotes to go onto the hotshoe. This is due to the non standard shoe shape of the Sony/Minolta cameras. You can connect the remotes to the PC terminal of the camera, however, that is rather cumbersome without a shoe mount.
Thu Mar 31, 2011 11:51 pm
I use Sony A900 and a700 and I have the inexpensive adapter which seem to work fine, but I mainly use the Sony adapter Model number: FA-HS1AM. YES it is pricey but I really like it. It worked great with my CC and Einstein.
Fri Apr 01, 2011 4:26 am
This brought back memories of when I used to shoot with an a900/a700 combo.. That hot shoe is such an annoying nuisance. Fret not, just purchase the adapter showing below(and stay away from the sony adapter, its overpriced JUNK)
http://www.flashzebra.com/products/0131/index.shtml
 [ 6 posts ]
Users browsing this forum: No registered users and 88 guests
