Vagabond and recycle times
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1342
Author:  Martin Reiter [ Tue Apr 05, 2011 3:20 am ]
Post subject:  Vagabond and recycle times
i would like to make sequences with flash (during sunset or night!): 3-4 fps (10-12 photos)
is it possible to do this with the vagabond mini or II and th einstein 640
the power should be 50Ws or more.
regards
Martin
Author:  Technical Support [ Tue Apr 05, 2011 11:10 am ]
Post subject:  Re: Vagabond and recycle times
That should be just doable with the VMini. Any higher power or any faster you may not be successful. A VII should be able to do that and give you a little wiggle room. Just tested 3 and 5FPS using those parameters and a Vmini. 3 was very consistent, 5 saw maybe a 1/3 drop from beginning to end over 10-15 shots. VII would provide faster recycling.
