| How to trigger E640s with CST on D90 with SB600 mounted? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1364 |
| Author: | socaltyger [ Wed Apr 13, 2011 3:24 am ] |
| Post subject: | How to trigger E640s with CST on D90 with SB600 mounted? |
Hi Everyone, hope this is an easy one. I have a CST and would like to trigger remote Einsteins with a Nikon D90 (no PC jack) that already has an SB600 mounted (again, no PC jack). The reason being... would like to use on-board speedlight as main/fill with remote Einsteins as rim lights. Is it as simple as some kind of hotshoe adapter? If so which one exactly? Much thanks in advance. |
| Author: | Technical Support [ Wed Apr 13, 2011 9:01 am ] |
| Post subject: | Re: How to trigger E640s with CST on D90 with SB600 mounted? |
The only way to do this to my knowlege is by using this adapter. http://www.pixelhk.com/pixelhk.com/Proshow.aspx?id=83 You can google it and find many retailers for it, or you can find it on eBay, I am sure. AFAIK, it is the only pass through TTL hotshoe adapter that also provides a PC port. I have one for my Sony, and it works well. |
| Author: | socaltyger [ Wed Apr 13, 2011 1:51 pm ] |
Thanks for the quick response, I will look for it. |
