B800 modeling lamp
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1367
Author:  Chalerdon [ Thu Apr 14, 2011 9:13 pm ]
Post subject:  B800 modeling lamp
I have purchased 2 B800s and I realized that the modeling lamps were warm colors like this to the point that it's hurting my eyes for some reason. I was wondering if it would be possible to replace the modeling lamp with a 150w white daylight color, and if it is would you kindly recommend me a good one? :lol: Thank you!
Edit: Also would someone recommend me a mid ranged boom arm? Thank you!
Author:  Technical Support [ Fri Apr 15, 2011 9:27 am ]
Post subject:  Re: B800 modeling lamp
Pretty much any model lamp from any manufacturer will have standard tungsten bulbs as their model lamps. These are typically not daylight balanced, as they are not intended to be used for exposure light. However, should you choose to use daylight balanced incadescent light bulbs, you certainly may. Be sure they do not exceed 150W. We do not have any specific reccomendations for this type of bulb.
