Einstein V2 speedring fingers sticking
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1380
Author:  Matt_Thomas [ Mon Apr 18, 2011 11:00 am ]
Post subject:  Einstein V2 speedring fingers sticking
Hi
I just received my Einstein on Friday and I'm beginning to notice that the release for the speedring does not spring back on its own I need to push the lever back to the top... is there anything I can do to fix this, they sprung back at first... I've been using the PLM V2 64" modifier on the speedring.
Thanks,
Matt
Author:  Pultzar [ Mon Apr 18, 2011 1:03 pm ]
Post subject:  Re: Einstein V2 speedring fingers sticking
Matt_Thomas wrote:
Hi
Thanks,
Matt
I am noticing something similar. My brand new E640 has a silky smooth feel to the mechanism. My slightly older lamps are starting to feel sticky. However they aren't as bad as yours yet. Mine still return on their own.
Author:  Technical Support [ Mon Apr 18, 2011 3:08 pm ]
Is there any spring resistence at all, or is it totally free moving?
Author:  Matt_Thomas [ Mon Apr 18, 2011 5:43 pm ]
There is spring resistance and a kind of grinding/ratcheting noise... kind of sounds like the spring is rubbing against something when I depress the release lever on the right... They seem to lock and occasionally release freely after I let go of the lever (when opening... I haven't dropped any modifiers or anything drastic like that.)
Author:  Matt_Thomas [ Tue Apr 19, 2011 12:01 pm ]
I played with the mechanism last night (opening and releasing many times) and it seems to be returning better now still have a grinding noise but it returns on its own now about 7/10 times using the left release and almost 10/10 times on the right release lever (when facing the control panel)... I can live with it but wanted to know if there's any way to lubricate the mechanism with either a wax based lubricant or graphite?
Author:  Technical Support [ Tue Apr 19, 2011 2:47 pm ]
That should nto be happening. Check with Customer Service about warranty service.
