Mon Apr 18, 2011 4:39 pm
Hi,
I remember this has been covered before but I can't recall where/when...
My ABs still have their original 100w modeling lights in service.
What type bulb and how many watts can I safely install for the 400 and 800 lights?
I seem to recall Sylvania 150w. If I am correct is this the max recommended power? I do understand more watts means more heat for modifiers to deal with. I wonder if the the 'old' recommendations hold true for the new more thicker/durable PCBuff soft boxes.
I have some daylight (blue coated) corrected photofloods around but not sure what the wattages are.
I am assuming that I do not need daylight corrected photoflood bulbs for the ABs as I am not using the bulbs for the exposure.
thanx,
Paul
Mon Apr 18, 2011 4:49 pm
No need for daylight bulbs, but 150W is max. This is not for the safety of the softboxes, but for the lights. For WYSIWYG, you would want a 150W in the B800 and 75-100W in the B400.
Tue Apr 19, 2011 11:31 am
thanks TS.
what's the recommended bulb?
Paul
Tue Apr 19, 2011 12:00 pm
Any non-compact flourescent edison based buld should work. We carry the 150W here: http://www.alienbees.com/tubes.html (150W is the part number).
Users browsing this forum: Google [Bot] and 40 guests
