| AB 400 and 800 modeling lights watts... http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1382 |
| Author: | PaulAuclair [ Mon Apr 18, 2011 4:39 pm ] |
| Post subject: | AB 400 and 800 modeling lights watts... |
Hi, I remember this has been covered before but I can't recall where/when... My ABs still have their original 100w modeling lights in service. What type bulb and how many watts can I safely install for the 400 and 800 lights? I seem to recall Sylvania 150w. If I am correct is this the max recommended power? I do understand more watts means more heat for modifiers to deal with. I wonder if the the 'old' recommendations hold true for the new more thicker/durable PCBuff soft boxes. I have some daylight (blue coated) corrected photofloods around but not sure what the wattages are. I am assuming that I do not need daylight corrected photoflood bulbs for the ABs as I am not using the bulbs for the exposure. thanx, Paul |
| Author: | Technical Support [ Mon Apr 18, 2011 4:49 pm ] |
| Post subject: | Re: AB 400 and 800 modeling lights watts... |
No need for daylight bulbs, but 150W is max. This is not for the safety of the softboxes, but for the lights. For WYSIWYG, you would want a 150W in the B800 and 75-100W in the B400. |
| Author: | PaulAuclair [ Tue Apr 19, 2011 11:31 am ] |
thanks TS. what's the recommended bulb? Paul |
| Author: | Technical Support [ Tue Apr 19, 2011 12:00 pm ] |
Any non-compact flourescent edison based buld should work. We carry the 150W here: http://www.alienbees.com/tubes.html (150W is the part number). |
