Sat Apr 30, 2011 3:23 pm
so i was reading the instruction manual and had never noticed that there was an SD card in the cyber commander. so i took it out just wanting to see what size it was. now my commander wont turn on when the sd card is in? i can turn the commander on when its, and the instant i put the sd card in, it turns off??
also, can i use this card to install the new V36? i have never saved anything on it so i dont see the need to use a new card?
Sun May 01, 2011 11:41 pm
The micro SD card is likely corrupt. You may be able to format it to FAT16 and have no further problems. However, if the card has corrupted once, it will likely do it again.
Users browsing this forum: No registered users and 29 guests
