| cyber commender wont turn on when SD card is in http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1416 |
| Author: | yamaha83 [ Sat Apr 30, 2011 3:23 pm ] |
| Post subject: | cyber commender wont turn on when SD card is in |
so i was reading the instruction manual and had never noticed that there was an SD card in the cyber commander. so i took it out just wanting to see what size it was. now my commander wont turn on when the sd card is in? i can turn the commander on when its, and the instant i put the sd card in, it turns off?? also, can i use this card to install the new V36? i have never saved anything on it so i dont see the need to use a new card? |
| Author: | Technical Support [ Sun May 01, 2011 11:41 pm ] |
| Post subject: | Re: cyber commender wont turn on when SD card is in |
The micro SD card is likely corrupt. You may be able to format it to FAT16 and have no further problems. However, if the card has corrupted once, it will likely do it again. |
