Vagabond II ALternate Battery?
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=142
Author:  cas5 [ Sat Jan 09, 2010 8:54 pm ]
Post subject:  Vagabond II ALternate Battery?
I've noticed that the Vagabond II battery is about 13 pounds, 20AH and will produce about 1200 full power flashes on a B800. I'd like to use the Vagabond very over my shoulder for a fairly short period of time and really need 100-150 flashes at something less than full power. Is it possible for me to switch out the batter to a lower AH, lighter battery?
Thanks,
Corey
Author:  geogecko [ Sat Jan 09, 2010 9:44 pm ]
Post subject:  Re: Vagabond II ALternate Battery?
Although I'm not sure it was ever answered, there was a very similar question asked near the bottom of this thread:
viewtopic.php?f=8&t=44&start=0&sid=4722be60f8ba6c8e0840b8151fb44748#p137
I would assume almost any sealed lead acid battery would work with Vegabond II. The chargers for SLA batteries generally look for a voltage delta to know when to stop charging, not how many Ah it has put in a battery. As long as you get a 12V SLA battery, I'd say you'd have little problems. Of course, the battery needs to have the capability of supplying enough surge current for a flash, which could probably be up to 50-60 amps, so you wouldn't want too small of a battery...
Maybe Paul will share some insight.
