Pocketwizard PowerMC2 very flakey *UPDATE*
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1420
Page 1 of 2
Author:  phodographer [ Sun May 01, 2011 12:19 pm ]
Post subject:  Pocketwizard PowerMC2 very flakey *UPDATE*
My Einsteins work perfectly with the Cybercommander system. And my speedlights all work perfectly with the Pocketwizard TTi system.
I was hoping to combine an Einstein with some Speedlights using the Power MC2, but it's given me nothing but grief. The Einstein frequently resets to a standard channel for no apparent reason, or simply stops responding to adjustments from my AC3. I can usually get it to work again by turning everything off and on again, but what a nuisance.
All my lights and slaves have been updated to the latest firmware.
Anybody else having these problems?
Author:  ericski [ Sun May 01, 2011 2:03 pm ]
Post subject:  Re: Pocketwizard PowerMC2 very flakey
Do you happen to have V1 Einsteins?
Author:  phodographer [ Mon May 02, 2011 11:47 am ]
No. I bought all my Einsteins in the last 2 months. And I've checked all firmware to make sure it's the latest. The MC2 just seems to lose its connection after a few frames.
Author:  Luap [ Mon May 02, 2011 11:57 am ]
LPA created the MC2 on their own, and directed firmware changes to Einstein to create the MC2/Einstein interface. So we will have to pass this on to LPA for technical analysis.
Author:  Mark Elberson [ Tue May 03, 2011 6:52 am ]
I have the exactly same problem. I usually have to remove and then re-insert the MC2 to resolve the issue which is a huge inconvenience in the middle of a session! I called tech-support and was told that this was a reported issue that they were investigating. I was also told that I would receive a call back regarding a solution...still waiting.
Author:  Technical Support [ Tue May 03, 2011 9:08 am ]
Which tech support? We have contacted Pocket Wizard and have not heard back.
Author:  Mark Elberson [ Wed May 04, 2011 12:43 pm ]
Paul C. Buff tech support. I asked if I should have been calling Pocket Wizard and was simply told that they knew of the problem and were looking into it. I was not advized to contact Pocket Wizard.
Author:  Ziv [ Wed May 04, 2011 3:20 pm ]
All
I have received quick responses from Ian at Pocket Wizard's "beta lab" when I have had issues with MC2.
Feedback/issues should be sent to PocketWizard via the “Inquires Form” on their “Contact” page or simply email them to betalab@pocketwizard.com and put "beta" in the subject line.
GZ
Author:  Technical Support [ Wed May 04, 2011 4:31 pm ]
Ok. They are still looking into the problem, we are recieving "progress" notices, but there is not a solution as of yet.
Author:  Technical Support [ Thu May 05, 2011 3:20 pm ]
Pocket Wizard has just informed us there is a Beta firmware for MC2 that is to address this issue. If you are interested, please contact them @
802-658-0038
extension 572
