 [ 12 posts ]
Wed May 11, 2011 11:45 am
I've set up our new Cyber Commander to work with our two new Einsteins and the ABR800 ringflash (using CSRB+) without a hitch. Each light is on a separate channel. Einsteins on 1 and 2, ABR800 on 3, and now the Speedlite 580EX II on channel 4. I've set up the Cyber Commander correctly. And I can trigger the Speedlite using the test button on the CSRB+.... but when I try to trigger from the Cyber Commander I get nothing..... although all of the other flashes that are setup trigger fine. Any thoughts?
Thanks!
Doug
Wed May 11, 2011 12:04 pm
Make sure the CSRB+ is on the same frequency as everything else. Anything beyond that is over my head.
Wed May 11, 2011 12:05 pm
I have all of the receivers set to their individual channels... but all are set to Frequency 01.
Wed May 11, 2011 12:26 pm
At the bottom of the graph, does CH 4 have a white dash, gray dash or no dash?
You should see white dashes under CH's 1-3 for a reference of where you are looking and what you are looking for.
Wed May 11, 2011 12:35 pm
It has a white dash.
Wed May 11, 2011 12:37 pm
By the way.... I'm using the mini-PC cable which came with the CSRB+
I have the 580EX II in Manual mode.... dialed down the power so I could test easier.
Wed May 11, 2011 12:41 pm
I have 2 580EX-II's and I have found triggering them via PC sync to be very squirrely. Make sure the flash isn't set to master or slave mode - I think that helped one time. But if the test button on the CSRB+ fires the flash consistently then that shouldn't be the problem.
Wed May 11, 2011 12:46 pm
Interesting......
The flash does fire consistently using the test button and PC sync... it just won't fire remotely via Cyber Commander... :-/
Wed May 11, 2011 12:47 pm
The flash isn't set in Master or Slave mode.....
 [ 12 posts ]
Users browsing this forum: Majestic-12 [Bot] and 23 guests
