2 Einstein in same stand. Any solution?
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1443
Page 1 of 2
Author:  igoralekseevcom [ Wed May 11, 2011 1:59 am ]
Post subject:  2 Einstein in same stand. Any solution?
I need put 2 Einstein on the same stand for overpowering the sun
I think T-adapter is best solution
Has anyone seen a solution?
Thanks!
Igor Alekseev
http://www.IgorAlekseev.com
Author:  PowerEngineer [ Wed May 11, 2011 6:33 am ]
Post subject:  Re: 2 Einstein in same stand. Any solution?
Besides a T-arm, you could attach the second light to the center column of the stand with a super clamp (which would keep the weight in close to the center line of the stand) or just use two stands right next to each other.
Author:  ltwimberly [ Wed May 11, 2011 9:13 am ]
Westcott makes a strong, inexpensive, counter-weighted boom arm - it's $86.49 on B&H. It mounts to the shaft of a heavy-duty light stand and leaves the top mounting stud open. That way you could configure 2 lights in the horizontal or vertical axis or anywhere in-between.
Author:  Technical Support [ Wed May 11, 2011 9:30 am ]
A "T"- topped stand would work, and could be made youself with little effort. A flat piece of steel with three holes, a couple of 5/8 spigots and a 1/4-20 nut and washer. Super Clamps are also a good choice in that they can be utilized in so many other ways.
However, overpowering the sun is more than just how much flash power is available. With the right modifiers (PLM, HOBD, 22RLR, 11LTR, etc.) and at the right distance, the sun can be easily overpowered by one E640 at 1/4 power. While it will not fix every situation, it is something to keep in mind while you try to find a solution.
Author:  igoralekseevcom [ Wed May 11, 2011 11:26 am ]
Thanks, perhaps I'll do that, DIY T-arm.
About "OPTS" (overpower the sun)
Tried PLM 86 Silver, Einstein - full power, 10-foot distance, f20, the sun with a few clouds - the results are not impressed
but what happens when the sun is no clouds in the picture or backlight?
the sun can kill only phosphoric military stun grenades? :twisted:
this test photos (just a BBQ with friends)
P.S.
After a review of Einstein, PLM, VB Mini on my blog, some studio equipment dealers in Moscow, asked not to write more about the PCB products :lol:
_________________
Igor Alekseev, photographer
http://www.igoralekseev.com
Author:  Technical Support [ Wed May 11, 2011 12:32 pm ]
How much overpowering do you want? Adding one E640 will yeild one stop (actually that may vary lower, depending on how it is modified. Example, sharing one PLM between two lights would not yeild the same focusing efficiency of one). Also, what ISO are you working with?
Author:  Luap [ Wed May 11, 2011 1:57 pm ]
P.S.
_________________
http://www.igoralekseev.com[/quote]
That's to be expected . . . photo dealers here hate us too because they can't sell our products. They attack me on forums, lie about me, defame me and get me banned from forums.
Also, recent information suggests the Russian government no longer allows residents to personally import products such as ours . . . protecting the stores and dealer network I suppose. Very bad isolationist move.
Author:  igoralekseevcom [ Wed May 11, 2011 3:31 pm ]
Luap wrote:
P.S.
Means you're invent and selling THE RIGHT STUFF, Paul!
Today I deleted 30 comments in my blog: "Chinese junk" "Customers will flee when he saw the inscription "Paul C Buff" on your photographic equipment " etc.
Not isolation, there is a banal theft in the russian post, but I and my friends bought your products through intermediaries or friends in the U.S.
Your products do not steal, because their value is not understood by thieves
Competition is not always fair, and who can he lobbied their interests and protect your business by any means, fortunately this is less true to the photo-equipment
I have tried to negotiate with a large retail photo store network in Moscow, but it profitable to buy a $ 100 chinese sleaze and sell it at $ 500 or buy $5k-10k top brand lighting equipment and sell at $ 10k-20k :?
_________________
Author:  c.d.embrey [ Fri May 13, 2011 2:58 pm ]
A Matthews Baby Double Header ($42.50) can mount four lights http://www.filmtools.com/badohe4.html
And a Matthews Baby Triple Header ($58.00) can mount five lights http://www.filmtools.com/batrhe4.html
A FilmTools 6" Double Headed Baby Pin ($10.65) http://www.filmtools.com/babypin1.html clamped in a Grip Head (C-stand) can hold two lights. Also available in 12" and 24" lenghts.
A FilmTools 5/8" Starter Pin w/ 3/8-16 female thread ($5.85) can be used to make DIY mounts http://www.filmtools.com/5stpinw3feth.html
Filmtools® 5/8" Baby Spud w/ 3/8-16 threaded hole in base ($3.75) http://www.filmtools.com/58babspudw381.html can also be ised for DIY projects.
Author:  igoralekseevcom [ Fri May 13, 2011 6:07 pm ]
Thank you, man!
