Old Ektachrome flashtubes?
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1447
Author:  Mack [ Wed May 11, 2011 4:52 pm ]
Post subject:  Old Ektachrome flashtubes?
I found a box of older Ektachrome flashtubes for the older White Lightening series - or that is what's written on the box. They appear to have a ribbon of a "gold color" in them.
Anyone know the color temperature of them and what they would be if I were only to put 1 tube in the W.L. making it 1/2 clear and 1/2 gold? I'm thinking they may warm skin tones up in lieu of using gold reflectors or umbrellas, but I have no color temp. flashmeter to tell the outcome for digital cameras. Anyone try this?
Any ideas as to what their color temp. was back then?
Tia.
Mack
Author:  Technical Support [ Thu May 12, 2011 4:22 pm ]
Post subject:  Re: Old Ektachrome flashtubes?
Was the "Ektachrome" printed, or handwritten on the box? We do carry UV coated and non-UV coated tubes, but we do not label them Kodachrome. However, we did/do recommend them for slide film. The UV coated ones do have a slight yellow cast compared to the non UV coated tubes. Since you have 2 tubes, I assume you have an Ultra series light. This will give you 5600K for the non UV tubes and 5200k for the coated ones.
Author:  Luap [ Thu May 12, 2011 4:27 pm ]
I have no idea of color temperature of flashbulbs, but would guess they are pretty close to "sunlight" IE around 5600° to 5800°K.
