| Speed Ring Adapter??? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=145 |
Page 1 of 2 |
| Author: | TobinJD [ Sun Jan 10, 2010 4:47 pm ] |
| Post subject: | Speed Ring Adapter??? |
This is probably way easier than I am making it, but Please Help! I recently picked up a AB Med Octobox and need to mount it on an RPS / Elinchrom strobe. What adapter Ring do I need? Thank You in advance for your help |
| Author: | Technical Support [ Mon Jan 11, 2010 10:07 am ] |
| Post subject: | Re: Speed Ring Adapter??? |
We do not offer a speedring to fit the Elinchrom mount. However, any standard speedring to fit Elinchrom should fit. The speedring is 7.5" in diameter, so make sure any that you buy are as well. TS |
| Author: | TobinJD [ Mon Jan 18, 2010 8:50 pm ] |
Can anyone help me find this? Good karma and eternal thanks to the helper. |
| Author: | The SB Image [ Tue Jan 19, 2010 1:56 am ] |
You just need any Elinchrom speedring that measures around 7.5 inches, the Elinchrom brand ones are ridiculously expensive so maybe look into buying a generic on Ebay or something. I have several different brand speedrings laying around and they all work with my boxes (Larson, Chimera and the Paul Buff brand) it looks like most have pretty much the same outer diameter TobinJD wrote: Can anyone help me find this?
| Author: | TobinJD [ Tue Jan 19, 2010 11:57 am ] |
I can purchase the speed ring and adapter for about $50 - since I already have a very functional speed ring I was hoping to save a few 4 and just get the adapter. Does anyone have one they would take $20 for? Cheers |
| Author: | TobinJD [ Mon Feb 01, 2010 7:21 pm ] |
FYI for this thread. I solved the mystery. A Photek Illuminata Adapter Ring fits the AB / 7-1/2" Speed Ring. They are less that $14. Scratch that. It doesn't fit. Would the ring adapter size be different if the Octobox is the older non colapsible model? The adapter ring measures 6" |
| Author: | TobinJD [ Sun Feb 07, 2010 5:11 pm ] |
Would the ring adapter size be different if the Octobox is the older non colapsible model? The ring I need will measure 6" not 5-1/2" ?? |
| Author: | Technical Support [ Mon Feb 08, 2010 12:16 pm ] |
Yes, the inner adapter plates are about 5.5" on the foldable and the standard speedring is about 6". Foldable adapter plates can be found here: http://www.porters.com/flash-studio/lig ... s.html?p=3 (and more on pg 4). These measure the same, but we have not tried them first hand. TS |
| Author: | TobinJD [ Wed Feb 10, 2010 1:08 pm ] |
No information on the non fold able (6") adapter rings? |
| Author: | Technical Support [ Wed Feb 10, 2010 3:27 pm ] |
No specific reccomendations for this. The best bet is to just buy a speedring for the light. Most will fit our softboxes, Chimera and Photoflex especially. TS |
