 [ 18 posts ]
Fri Aug 26, 2011 5:58 pm
Has anyone else had issue with the Einstein flash "leaking" through the cooling vents? I've done some controlled light set up and light comes through the vents. I've had to gaffer tape over the cooling vents, turn off the modeling bulbs and pray the unit doesn't overheat. I don't notice this issue with setups that are more "light bomb" oriented.
Fri Aug 26, 2011 8:02 pm
The amount of light you're talking about is inconsequential.
Fri Aug 26, 2011 9:00 pm
I'll shoot an example next week and send it to you so you can see what I'm talking about.
Fri Aug 26, 2011 11:59 pm
Nice stuff on your site
Were the headahots done with Einstein?
Sat Aug 27, 2011 6:47 am
Thanks! Some of them were done with Alien Bees and some were done with Einsteins.
Sat Aug 27, 2011 7:20 pm
Rather than straight taping over the lights you might consider making gaffer tape louvers or using some screen. This way you still get airflow while also blocking the light.
FWIW, I haven't found this to be an issue with my Einsteins.
Sat Aug 27, 2011 10:21 pm
I suppose under extremely unique usage that this might be a concern, but I have not encountered it. Rather than tape over the vents, which seems like a really bad (potentially warranty-voiding) idea, buy some cinefoil (roll costs around 25-30 bucks, maybe). It is incredibly useful stuff for many applications, but you should be able to make some custom shaped flags that block the light but leave airflow unhindered.
Mon Aug 29, 2011 12:04 am
Your portaits really do look good.
Tue Aug 30, 2011 10:54 am
I take back my original post - I just did some additional testing and I was wrong and Paul is right. Any light coming from the cooling vents is absolutely inconsequential.
Tue Aug 30, 2011 11:18 am
Ahh, the rarest of message board finds.... a mea culpa! It is always good to see someone exhibit class and respect on the internet. Nice!
 [ 18 posts ]
Users browsing this forum: No registered users and 25 guests
