| VML with Speedotron Force 10's http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1482 |
| Author: | Thesepaperwings [ Fri May 27, 2011 8:17 am ] |
| Post subject: | VML with Speedotron Force 10's |
Just thought I would let people know that the VML DOES work with the Speedotron Force 10 and Force 5 units. They need to be on slow recycle but I was pretty sure they would because of the draw. I would advise against the use of the modling light, it's a 250watt bulb and you can almost see the battery draining. Half power is around 3 seconds (half power on a 1000watt head is more then most people will ever need) Full power is around 8. Looking back I forgot to try multiple heads so I will try that this weekend and see what the time will be. |
| Author: | Technical Support [ Fri May 27, 2011 10:07 am ] |
| Post subject: | Re: VML with Speedotron Force 10's |
Thanks for sharing this info! If you do try multiple heads, please let us know! |
| Author: | Thesepaperwings [ Wed Jun 01, 2011 11:02 pm ] |
Two heads is a no go, but we all knew it would be so it's ok. |
| Author: | Luap [ Thu Jun 02, 2011 2:58 am ] |
Four or even five 640WS AB1600s work fine on Vagabond Mini. But four at full power you'll have to wait about 14 seconds for recycle. Much faster at reduced power. |
| Author: | kenyee [ Thu Jun 02, 2011 9:24 am ] |
Thesepaperwings wrote: Two heads is a no go, but we all knew it would be so it's ok. I'm surprised you got one to work...the Force 10 has an old intel 386 compatible chip as a controller IIRC...should have been pretty sensitive to brownouts ;-) |
| Author: | Luap [ Thu Jun 02, 2011 11:05 am ] |
The uP has nothing to do with this. It's the power supply design. |
| Author: | Thesepaperwings [ Thu Jun 02, 2011 11:06 am ] |
There seems to be no problems as long as the light is on slow recycle. I don't use the modeling light so that helps as well. kenyee wrote: Thesepaperwings wrote: Two heads is a no go, but we all knew it would be so it's ok. I'm surprised you got one to work...the Force 10 has an old intel 386 compatible chip as a controller IIRC...should have been pretty sensitive to brownouts ;-) |
| Author: | Luap [ Thu Jun 02, 2011 11:09 am ] |
Makes sense . . . fast recycle equals more charging current and lower inverter voltage. Same with Profoto. |
| Author: | photoshutter [ Sun Jun 05, 2011 3:51 am ] |
I tried today VML with two Broncolor Minicom 80 in slow charge, without problem, at full power recharge around 10sec |
