| cyber commander help http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1486 |
| Author: | imposterjeff [ Sat May 28, 2011 9:26 pm ] |
| Post subject: | cyber commander help |
ok i purchased a used cyber commander and csr+ earlier this week and well it wont adjust the power of the output the bar moves down on the graph but the power output stays the same.also the lightmeter does not read. i am probably doing something wrong here so i could use all help |
| Author: | imposterjeff [ Sat May 28, 2011 10:16 pm ] |
| Post subject: | Re: cyber commander help |
also when it is plugged in to my vagabond it just randomly fires like a strobe light |
| Author: | Technical Support [ Sun May 29, 2011 8:16 pm ] |
Make sure you have your channels and frequencies matching. Also, make sure the RJ11 (telephone) cord plugged in and the power slider to the far right. As for the VII, there may be a grounding issue in it. This can be repaired, if the VII is sent in. For further asistance on Cyber Commander programing, it may be easier to call in on Tuesday. |
| Author: | imposterjeff [ Sun May 29, 2011 8:44 pm ] |
not a problem i will call Tuesday for sure. also on the random flashing it has done it on every outlet i have used |
| Author: | imposterjeff [ Mon May 30, 2011 8:53 am ] |
ok i got everything worked out on setting it up. Now when i plug the csr+ in to the flash and get everything ready on the b1600 and the vagabond II its like the commander will not communicate with it. |
