Vagabond II alternate uses?
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1503
Author:  editguy [ Sun Jun 05, 2011 3:37 pm ]
Post subject:  Vagabond II alternate uses?
Can a Vagabond II be used to charge camera batteries in a pinch? Will I risk damaging either the Vagabond or the batteries I am charging?
Author:  PowerEngineer [ Sun Jun 05, 2011 5:01 pm ]
Post subject:  Re: Vagabond II alternate uses?
The VBII will run/charge just about anything that takes 60-Hz 120-V power as long as it is less than the vagabond's max power output. Charging normal camera batteries should be fine.
Author:  editguy [ Sun Jun 05, 2011 6:36 pm ]
Thank you PE
