Alein Bee B800 won't flash
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1524
Author:  hrbrooks [ Sat Jun 11, 2011 12:05 pm ]
Post subject:  Alein Bee B800 won't flash
I purchased 2 Alein Bee B800 unit a couple of months ago. I setup a used them just for testing the first week and everything worked great. I get them out today to shoot a couple of people for passports and now one of the B800 units won't work.
Power light is on.
The green light is on.
The test button won't flash or make a sound like it is trying to flash.
The model lamp button will light the bulb.
I have switch bulbs in both units and the same unit doesn't work with either bulb.
switched power cables.
Need advise.
Thanks,
Herbert Brooks
hrbrooks@mediacombb.net
229-300-2732
Author:  Technical Support [ Mon Jun 13, 2011 8:43 am ]
Post subject:  Re: Alein Bee B800 won't flash
Since you swapped flash tubes, this tells me the problem is in the head. You will need to contact Customer Service for warranty service options.
