| CyberCommander Metering via Sync Port http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1534 |
| Author: | James [ Tue Jun 14, 2011 9:06 am ] |
| Post subject: | CyberCommander Metering via Sync Port |
Can I have a light assigned to the CC sync port for metering? I was thinking of getting a CC and CXSCV for my Einstein so I can meter and adjust settings remotely. Let me know if this scenario will work... Plug my Radiopopper JrX transmitter into the sync port of the CC via cord and hot shoe adapter. Now meter and set power on the Einstein, then use the sync port to fire and meter the speedlight, adjusting power with the knobs on the JrX transmitter. Now if I need to make any adjustments while shooting I can simply use the menu on the CC and knobs on the JrX setup. Thanks, James |
| Author: | Technical Support [ Tue Jun 14, 2011 11:37 am ] |
| Post subject: | Re: CyberCommander Metering via Sync Port |
The Cyebr Commander's PC is input only. You can connect the RP transmitter to a CSRB+ and otherwise do as you described. |
| Author: | James [ Tue Jun 14, 2011 12:39 pm ] |
Thank you. It's looking like I need to eBay the RPs and go with all Cyber Syncs. Should have done that in the first place. :roll: James |
