| CSXCV with skyports http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1552 |
| Author: | martinhallberg [ Mon Jun 20, 2011 4:10 am ] |
| Post subject: | CSXCV with skyports |
Hi! I wonder if i can use the cybercommander with the CSXCV on my einsteins to control them remotely and measure them. But still be able to use my skyport to trigger them? I would have the cc as a remote handheld and my skyport transmitter in the hotshoe and the skyport recivers connected to the enistens via the 3.5mm jack. Thanks! |
| Author: | Technical Support [ Mon Jun 20, 2011 9:04 am ] |
| Post subject: | Re: CSXCV with skyports |
It is rather redundant, but yes, you can trigger this way. Or, if you have other lights that are using the Skyports, you can connect a CST to a Skyport reciever. When the reciever is triggered, it will trigger the CST to fire the lights. This will save you from buying additional Skyports. |
| Author: | martinhallberg [ Mon Jun 20, 2011 10:15 am ] |
The thing is that i allready have three receivers and a transmitter for the skyport system. With my solution I only have to buy a cc and two cxscv instead of buying a cc, a cybersync transmitter, two cxscv and two receivers for my other lights. I understand that I won't be able to meter my other lights with the cc and that's a shame. Thanks for your answer! |
