| Speedrings http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1565 |
| Author: | Chico [ Fri Jun 24, 2011 11:44 am ] |
| Post subject: | Speedrings |
Any recommendations on how to attach two PCB speed rings together? |
| Author: | Technical Support [ Fri Jun 24, 2011 12:22 pm ] |
| Post subject: | Re: Speedrings |
It would help if you described exactly how you wanted them in relation to each other. Also, the final intent may be of help as well. |
| Author: | Chico [ Fri Jun 24, 2011 12:26 pm ] |
Technical Support wrote: It would help if you described exactly how you wanted them in relation to each other. Also, the final intent may be of help as well. Mounting two light into a Chimera Softbox. |
| Author: | Technical Support [ Fri Jun 24, 2011 2:27 pm ] |
I dont think our speedrings would be sized properly for that purpose. There is this product which may help (or one like it): http://www.adorama.com/CMDHBSA.html. I do not know what, if anything, else would be required. |
| Author: | Chico [ Fri Jun 24, 2011 3:41 pm ] |
What are the dimensions of your ring? Will PCB sell me a few Strobe Mounting inserts? |
| Author: | Technical Support [ Fri Jun 24, 2011 4:31 pm ] |
7.5" in diameter at the rod holes. 6" outer diameter of the speedring insert. We do not have inserts for sale seperately (they are prepackaged with the outer rings when they are recieved). |
