 [ 12 posts ]
Sun Jun 26, 2011 7:08 pm
I'm using the Radiopopper JrX system with the X1600. When I hook up the JrX receiver to the X1600 via the remote link & test it indoors, everything works the way it should. However, when I use the setup at an outdoors location, the Jrx receiver is not transmitting to the X1600 via the remote link. This has happened on the only two occasions that I tried to use this setup outdoors. Very frustrating when I'm trying to do a shoot. The JrX receiver will work as a dumb trigger when I use the sync cable. Since I don't have backup equipment, how can I test to see if the X1600 remote is causing the problem? Thanks.
Mon Jun 27, 2011 7:45 am
How are you powering the light outdoors? The issue is likely power supply related. If you can set the light up inside with an extension cord and get the light to work, move the light outside leaving plugged where it is. If it works fine, then it is not an environmental thing.
Not knowing what is wrong, things to eliminate are faulty extension cords, faulty power strips, and improprly wired AC outtlets, or ones with a lot of noise on them.
Mon Jun 27, 2011 11:43 am
I'm using the VML battery pack to power the X1600 outdoors. My setup using the Remote didn't work during my outdoors shoot this past Saturday. On the next day Sunday, I tested the setup using the Remote with the VML battery pack indoors & everything worked again. So I'm totally lost on why my setup isn't working outdoors but will work indoors.
My first outdoors shoot was at a city park. My second & last outdoors shoot was at the desert. I'm thinking out loud, is the RJ-11 connection more susceptible to noise interference than the sync cord connection?
When I first encountered this problem, I blamed the "bad" RJ-11 cable but it appears that I was too hasty in putting the blame on the original cable. The replacement cable from Radiopopper didn't work on my last outdoors shoot. Trying these same two cables, my setup works indoors. I have also emailed Radiopopper support about my problem.
Mon Jun 27, 2011 11:51 am
Are you setting the power sliders on the light to "FULL"?
Are you getting a green OK light, or red DUMP light when it does not work?
Did you try the model lamp on/off switch in each on and off (the switch on the light)?
Does the flash fire at all when it is not working properly?
By the way, I am asking questions that I would ask if it were CyberSyncs. I do not know enough about RP's to specifically trouble shoot them, though I would image similar characteristics.
Mon Jun 27, 2011 12:20 pm
Slider set to FULL.
Getting the green light regardless of the status of the JrX receiver.
Update: When I turn on the receiver, the red dump light is on & then changes to green after a few seconds.
Model lamp turned off since I'm using a beauty dish.
The X1600 will fire when pressing the TEST button on the X1600 or pressing the trigger using the sync cord connection for the JrX receiver.
However, it will not fire when I use the Remote hookup when pressing the trigger & also will not get the test fire when the receiver is turned on. So something is causing an interference with the communication between the JrX receiver & X1600. And I don't think it's the RJ-11 cable that's causing my problem.
No problems with your questions as you are trying to help me. Thanks.
Mon Jun 27, 2011 2:41 pm
I am not sure why the beauty dish has an imact on this choice, though the model lamp should not be used due to its drain on the battery pack. However, turn the model lamp on on thw back of the light, and use the dip switch on the reciever to turn it off.
Mon Jun 27, 2011 3:44 pm
I updated my answer to question #2 above.
I turned back on the model lamp on the X1600. However, it appears that the dip switch (#8) on the JrX receiver doesn't turn off the model lamp in either the on or off position. It just made the model lamp go from bight to less bright. So I turned off the model lamp on the X1600 instead.
On another note, I'm testing my X1600 in the garage right now with the remote working as it should. I'm noticing that with the Slider on Full that turning on the JrX receiver, the test flash is not at 1/1 but at a low setting like 1/128. It should not matter that the JrX transmitter is set at full power & it's the last one to get turned on.
Mon Jun 27, 2011 3:50 pm
Not exactly true. The "tickler" flash is often accompanied by a red dump light. This is an indication the reciever has not gotten any instructions on how to adjust the flash. Usually, by turning on the transmitter, and possibly making an adjustment, the light should go to a reasonable setting. (this is how it works on CS, anyway)
One other place to look on the light; look inside the RJ11 connection. You should have 4 contacts, all of which should be evenly spaced, and at the same height. The same should be true of your reciever.
Mon Jun 27, 2011 4:34 pm
The RJ-11connectors appears to be OK on the X1600 & receiver. On the next outdoors shoot, what should I take note on if I encounter this problem again? I also need to find another AB or WL strobe to test my JrX system with which would help me greatly. Thanks for your assistance.
Tue Jun 28, 2011 9:21 am
This means you're using the VML?
FWIW, I've never seen this behavior w/ my JrX....flickering red stuck ready light yes (from opamp lockup/latchup at low voltage), but no utter lack of power control like you described.
 [ 12 posts ]
Users browsing this forum: Google [Bot] and 75 guests
