| How to set 1/3 increments with Cyber Commander http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1594 |
| Author: | sdegan [ Thu Jul 07, 2011 6:16 pm ] |
| Post subject: | How to set 1/3 increments with Cyber Commander |
Hi, Is there a way to set the increments in 1/3 f/stop (instead of a full f/stop) with the Cyber Commander? If, for instance, I want to set the ISO at 160 or 320 what am I supposed to do? Any suggestion? Thanks |
| Author: | Technical Support [ Thu Jul 07, 2011 8:29 pm ] |
| Post subject: | Re: How to set 1/3 increments with Cyber Commander |
ISO and Shutter speed settings are only available in full stop increments. However, you can dial in +.3 or +.7 under the CAL heading in the upper right in the same screen to simulate 1/3 stop adjustment for ISO (since ISO affects exposure globally). This will not work for shutterspeed. |
| Author: | sdegan [ Fri Jul 08, 2011 9:04 am ] |
Many thanks, Is there any plan to introduce the 1/3 increment with a firmware update? Thanks again. |
| Author: | Technical Support [ Fri Jul 08, 2011 11:23 am ] |
It has been discussed, but I do not know when or if it will happen. It is not easy or inexpensive. |
