| clip for Vagabond Mini http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1600 |
| Author: | starbase109 [ Fri Jul 08, 2011 4:05 pm ] |
| Post subject: | clip for Vagabond Mini |
Is there a trick to getting this stand clip to function properly? I have both the standard AB stands and one of the heavy duty stands. I the clamp is too small for either stand. |
| Author: | Technical Support [ Fri Jul 08, 2011 4:22 pm ] |
| Post subject: | Re: clip for Vagabond Mini |
You can loosen the tightening knob until the clamp opens to seat around the stand. I does not necessarily completely encircle the stand. Then tighten the knob back. You should also rest the unit on one of the knuckles on the stand. |
| Author: | starbase109 [ Fri Jul 08, 2011 4:31 pm ] |
the spring on the screw prevents that. In order to get the clip to open up at all, you nearly have to unscrew it to the point where it come off completely. |
| Author: | starbase109 [ Fri Jul 08, 2011 4:34 pm ] |
i can get it to attach to the very top of the heavy duty stand, but not the bottom part where the stand is most stable. clamping it other than the bottom section keeps me from using the stand at it's lowest , and makes the stand a little top heavy |
| Author: | Luap [ Fri Jul 08, 2011 10:22 pm ] |
I'll eventually design a better stand clamp, but I am soooooo busy. Some important new things in the works. In the meantime, I recommend bungee cord. |
| Author: | BigIronCruiser [ Fri Jul 08, 2011 11:44 pm ] |
Elastic/stretch Velcro. Works great. |
| Author: | starbase109 [ Sat Jul 09, 2011 5:23 am ] |
that's what I wound up using. Bungee cords work great. The device itself it awesome. powered all 4 of my AB heads with no lag. love the thing. |
| Author: | Photoflight [ Sat Jul 09, 2011 2:04 pm ] |
I had a 1/4-20 connector and a Mafer Clamp (Manfrotto Super Clamp) that I put together with the VML. The MaferClamp holds the VML securely to any stand section I need it to. If you already have some Mafer Clamps it's a fast and easy way to go. Bill F |
| Author: | hjoseph7 [ Sat Jul 09, 2011 5:31 pm ] |
I wrap the shoulder strap around one of the clips on the light stand. That seems to work for me. |
