| Question On AlienBee 800 http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1609 |
| Author: | BUroKHUli [ Tue Jul 12, 2011 12:01 am ] |
| Post subject: | Question On AlienBee 800 |
Hi, what is the TRUE WATTS for AB800? thanks |
| Author: | PowerEngineer [ Tue Jul 12, 2011 8:38 am ] |
| Post subject: | Re: Question On AlienBee 800 |
I'm guessing you mean watt-seconds (Ws) rather than watts? If so, then 320 Ws per the AB800 page: http://www.paulcbuff.com/b800.php. The thing is, Ws is not a great way to compare lights, especially across brands. Ws is a measure of the energy stored in the capacitors and available to the flash tube - not a measurement of light intensity from the tube. It can be more useful to compare f-stop at a defined distance with a common modifier..... http://www.paulcbuff.com/output.php. |
| Author: | BUroKHUli [ Tue Jul 12, 2011 12:11 pm ] |
Hi sir, The reason for asking you this question is that we are planning to buy a portable generator for our lights. And I need to be sure how many WATTS not W/sec an AB800 has so that we can buy the right kind of generator. thanks |
| Author: | PowerEngineer [ Tue Jul 12, 2011 12:20 pm ] |
Ooops, wrong assumption on my part. :oops: The common advice is to size the generator at 1000 watts per flash that you will be running. Also make sure you are using a generator with a pure sine wave output. |
| Author: | BUroKHUli [ Wed Jul 13, 2011 5:08 am ] |
I already scouted for the supplier and they have a PURE SINEWAVE OUTPUT generator. All I need is to choose how much WATT power. |
