Tue Jul 12, 2011 12:01 am
Hi,
what is the TRUE WATTS for AB800?
thanks
Tue Jul 12, 2011 8:38 am
I'm guessing you mean watt-seconds (Ws) rather than watts? If so, then 320 Ws per the AB800 page: http://www.paulcbuff.com/b800.php.
The thing is, Ws is not a great way to compare lights, especially across brands. Ws is a measure of the energy stored in the capacitors and available to the flash tube - not a measurement of light intensity from the tube. It can be more useful to compare f-stop at a defined distance with a common modifier..... http://www.paulcbuff.com/output.php.
Tue Jul 12, 2011 12:11 pm
Hi sir,
The reason for asking you this question is that we are planning to buy a portable generator for our lights. And I need to be sure how many WATTS not W/sec an AB800 has so that we can buy the right kind of generator.
thanks
Tue Jul 12, 2011 12:20 pm
Ooops, wrong assumption on my part. :oops: The common advice is to size the generator at 1000 watts per flash that you will be running. Also make sure you are using a generator with a pure sine wave output.
Wed Jul 13, 2011 5:08 am
I already scouted for the supplier and they have a PURE SINEWAVE OUTPUT generator. All I need is to choose how much WATT power.
Users browsing this forum: Google [Bot] and 44 guests
