 [ 11 posts ]
Thu Nov 17, 2011 3:35 pm
Thought I would test out my Canon G12 with the Cyber Commander for an alternative way of shooting the AB800's. No joy . It will fire a Canon 580EX II without any problem but does not seem to trigger my strobes. I have tried both the Cyber Commander as well as the Transmitter. Anyone else try this? What have been your results?
Thu Nov 17, 2011 3:50 pm
FWIW, folks in the flickr strobist forum have used the CST w/ the Canon Gxx cameras and reported high sync speeds...not sure what the issue is w/ yours though...
Thu Nov 17, 2011 4:12 pm
Maybe my settings are wrong for shooting with the camera body. I set it to the same as my Canon 7D - ISO 100, Manual, F 8.0, 1/250
Thu Nov 17, 2011 4:58 pm
kenyee wrote:
FWIW, folks in the flickr strobist forum have used the CST w/ the Canon Gxx cameras ...
While a G9 will be very similar, it does not mean the same as a G11 or G12. I am not saying this is or is not the case, but...
Thu Nov 17, 2011 4:59 pm
I presume this means the CC worked fine on a different body? Try pressing down on the CC while trying to take a photo. This will force the foot down incase it is not making contact.
Thu Nov 17, 2011 5:01 pm
Also, turn live view off and use the viewfinder to see if this makes a difference. It can on Canon DSLR's. Also try toggling the flash mode to/from manual and auto.
Thu Nov 17, 2011 5:21 pm
I have used the Cyber Commander successfuly with the Canon 7D and 50D with the light setup the same way. I'll give your suggestion a try to see if it is a contact problem.
Thu Nov 17, 2011 6:02 pm
Turning off the display seemed to have done the trick. Thank you for your help.
Thu Nov 17, 2011 6:06 pm
There may be a menu option to allow LCD screen to be used.
Thu Nov 17, 2011 9:33 pm
technical support nailed it.
i've had the g12 and used the cybercommander with it and ran into the same hiccup: live view settings in the menu disable firing a flash at the same time. In the canon 5d2 and 50d you have to turn off silent shoot in the menu so that the flash will fire normally.
also: make sure you are not in continuous mode shooting as this will disable your hotshoe when using a canon point and shoot with an external hot shoe.
 [ 11 posts ]
