 [ 18 posts ]
Sat Jun 11, 2011 1:32 pm
Just received my new Cyber Commander and have been through the manual several times. I have everything working but every time I wake it up it comes up with a screen that says "Cannot read SD card". I can move off the screen and use it normally but it is really a pain to have to switch screens everytime I wake it up. I have formated the card in the cyber commander and I am able to save settings to it. What can I do to stop this screen from popping up?
Mon Jun 13, 2011 8:46 am
Try formatting it in a computer, preferably a PC. Format to "FAT" a.k.a. FAT16. Formatting to FAT in a Mac will format to FAT32 which will not work. If you have done this, and continue to experience problems, please let us know. Also, until a solution is found, the CyberCommander can be used without the card, limited only to two internal save locations.
Mon Jun 13, 2011 12:30 pm
I was about to post concerning the exact same issue when I saw this thread.
I received my Cyber Commander today and also get the "Cannot read SD card". I tried formatting with the CC itself, then on a PC in FAT. I still get the error message when I power up the CC.
If you want me to test something else, I'm available.
Thanks
Patrick
Mon Jun 13, 2011 3:08 pm
Since you have formatted on a PC since trying in the Cyber Commander, try formatting in the CC again.
Mon Jun 13, 2011 4:01 pm
I put the SD into the CC immediately after formatting from the PC.
I get the "Cannot read SD card"
I format the card from the CC. The CC reboots and there's no error message. I can save to the SD using the "Save as" menu.
The CC powers itself down after 20 secs.
On wake-up, I get the message "Cannot read SD card"
I pull the SD from the CC and put it in the PC.
I can see 2 files in the PCBUFF\CCMDF\CONFIGS directory:
SD000001.SAV and SD-DATA.HEX, both of them are 1KB in size.
If I put the SD back in the CC, I still get the error message.
If I pull the batteries from the CC and put them back in, on first boot, I don't get the error message, but I get it on each wake-up after.
Seems like on cold boot, the CC sees the SD correctly, but on wake-up, it doesn't.
Anything else I can test?
Patrick
Mon Jun 13, 2011 4:03 pm
Oh, and I don't want to hijack TracyMc thread. Maybe he could tell us if he sees the same behavior on his CyberCommander. If not, I'll start a new thread or email tech support directly.
Patrick
Mon Jun 13, 2011 4:40 pm
They are related closely enough, I would not consider it hijacking. We are looking into this, so please bear with us, and thank you for your feedback.
Wed Jun 15, 2011 5:14 pm
I received my Einsteins and CyberCommander 2 days ago and have the exact same problem. Would it make sense to buy a third party SD (they're cheap enough) and try to format that or wait until you have done some further research? Thanks.
Wed Jun 15, 2011 7:13 pm
TS- Can you just ship them out already formatted until you find a solution? I'm a mac user and i just order mine today.
Is the SD card just for storing settings or firmware updates?
Thu Jun 16, 2011 8:57 am
You can if you wish, however we are looking into the problem deeper, and once we find a solution, we will gladly correct the problem for you. The card is only necessary for saving set ups and firmware updates. Otherwise, the CC is fully functional, but limited to 2 SD save locations.
 [ 18 posts ]
Users browsing this forum: No registered users and 36 guests
