HappyCamp wrote:
I have a Request For Enhancement (RFE)
Can the CyberCommander add a 1/200 second shutter speed option for the light meter?
Currently it goes from 1/125 second to 1/250 second.
I usually shoot at either 1/160 second or 1/200 second (fastest shutter speed I can use with external flash). So it would be nice if the light meter could support those shutter speeds too.
Possible with added programming to CC. But indoors you won't see any difference in meter reading at 1/125, 1/160, 1/200 or 1/250. Outdoors you shouldn't see much difference unless the primary light is mostly ambient. Even then, metering at 1/250 and shooting at 1/200 isn't likely to yield more than 1/6f error.
