Cyber Commander Firmware v.40 Announcement! 8-3-11
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1667
Page 1 of 2
Author:  Technical Support [ Wed Aug 03, 2011 12:46 pm ]
Post subject:  Cyber Commander Firmware v.40 Announcement! 8-3-11
Cyber Commander owners!
Thank you for your recent purchase of the Paul C. Buff, Inc. Cyber Commander! As always, Paul C. Buff, Inc. strives to offer unrivaled support for our products, not only with updates for current products, but looking into the future as well. With this in mind, Paul designed the Cyber Commander (as well as Einstein) to have user-upgradable firmware, which can both fix operational problems as well as add functions to the product.
Today, we are announcing the availability of Cyber Commander version 40 firmware which will enhance the use of your Cyber Commander. For instructions on downloading and installing the update, please visit this link, scroll down and click on the "Firmware Updates" tab. http://www.paulcbuff.com/cc.php. All you will need to perform the update is a new MicroSD card (2GB or smaller), a computer with internet access, and a card reader capable of reading and writing to the MicroSD card.
We hope you find this update beneficial. As always, if you have any questions, please visit our Tech Forum viewforum.php?f=8 or feel free to contact our Customer Service department at 1-800-443-5542 or email us at info@paulcbuff.com.
Author:  c2thew [ Fri Sep 02, 2011 11:57 am ]
Post subject:  Re: Cyber Commander Firmware v.40 Announcement! 8-3-11
Found a bug:
If you cycle through the menu to the advanced configuration setting and open it, then let the cybercommander fall into sleep mode: the cybercommander will wake up with a bunch of horizontal text lines and a frozen menu interface. Though you can get access to the main light menu by thumbing the right joystick, the left joystick at that time will have no effect.
Author:  Technical Support [ Wed Sep 07, 2011 9:31 am ]
I have not been able to replicate this problem. Try removing the SD card to see if it happens then.
Author:  c2thew [ Wed Sep 07, 2011 12:48 pm ]
Tried removing the micro sd 2gb card but still had the bug. Must be an isolated issue if you aren't detecting it on your side. Doesn't affect functionality, just wanted to see if you guys had seen it.
Author:  Technical Support [ Wed Sep 07, 2011 3:41 pm ]
Hmm. Originally, I tested with an antenna version CC, and could not replicate the issue. I then tried on my antenna-less CC and the issue appears. It is possibly due to hardware drivers for different screen versions (neither are better or worse, just different). I will pass this along to engineering.
Author:  Btdross [ Sat Sep 17, 2011 12:42 am ]
Is there any way to install the update from a Mac? I don't have a PC at home (and thus can't write FAT16). Any workarounds to the microSD formatting? In case it is any help, I'm running OS X 10.6.3. I'd love to take the Cyber Commander from v.29 to v.40!
Thank you in advance for any suggestions.
Author:  Technical Support [ Sat Sep 17, 2011 8:40 am ]
you can try simply erasing the card. If the card is OK, it should nor absolutely require formatting. We just strongly recommend it when possible.
Author:  digitalartthatrocks [ Sat Jun 15, 2013 10:46 am ]
Help Please!
I tried updating my cyber commander (the no antenna version) from version 27 to 40 and have completely failed to do so. I downloaded the new software, inserted the SD card from the Cyber Commander into my Mac and copied the BCBUFF folder containing the CCMDR folder overriding the old one. Put the MicroSD card back into the Cyber Commander, it flashed white several times and just never stopped flashing white. So I tried to put the older BCBUFF folder back onto the card (which I backed up) and it wouldn't let me. So I tried using the Disc Utility, and just erasing the card, tried putting on the old firmware v27 back on and now I have nothing but a black screen almost as if it doesn't work.
Obviously, I did this procedure wrong. What can I do at this point? This is my only wireless trigger. Without it I cannot use strobes. Please help!
-Brian
Author:  Technical Support [ Sat Jun 15, 2013 1:23 pm ]
Try erasing everything on the card. DO NOT FORMAT IT! The reload the new firmware on the card, as per the included instructions, and try again. If this fails, you can try using a different 2GB or smaller microSD card to see if the Cyber Commander likes that card any better.
If both of these fail, we will need to have the Cyber Commander come in for service.
Author:  digitalartthatrocks [ Sat Jun 15, 2013 4:32 pm ]
Thanks for the quick response! I actually tried erasing the card via Apple's disk utility. I simply erased, not formatted it. I just a black screen at this point as if it wasn't turned on. My dad has a PC, gonna try formatting to FAT16 and putting the new firmware back on the card tomorrow. If that doesn't work, I will definitely be more than happy to send it in for service. Who would I need to get a hold of to do so if that is the case? And what kind of cost is involved in that? I've had my Cyber Commander for probably a little over 2 years now... Thanks again!
