| Protect Your Cyber Commander Screen http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1671 |
| Author: | ImageX [ Thu Aug 04, 2011 4:42 am ] |
| Post subject: | Protect Your Cyber Commander Screen |
Hey all, just thought I'd share what I did. As you know, the CC screen is plastic and plastic is prone to scratching. There isn't a purpose cut screen protector for the CC so what you can do is buy a back of universal screen protector such as the Griffen's... available at Walmart. A pack of 5 is about $6. Instead of trying to cut it perfectly first, just cut an over sized piece. Peel off the backing and lay it over the screen and smooth it out. It should overlap all the way around. Next, grab your x-acato knife or another razor. There is enough of an edge along the LCD screen to act as a guide for your blade. It's easy to do and you now have a perfectly cut screen protector for your precious CC. 8-) |
| Author: | Technical Support [ Thu Aug 04, 2011 2:17 pm ] |
| Post subject: | Re: Protect Your Cyber Commander Screen |
Nice tip. Also, if given the choice, I would recommend low/no glare over a glossy finish as well. |
| Author: | Deafy Dad [ Sun Aug 07, 2011 4:01 pm ] |
Maybe pcb should offer that protect sheets and I'll look into that soon when I buy cyber commander |
