Cyber Commander V1 won't accept Firmware update
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1675
Author:  dmward [ Fri Aug 05, 2011 2:50 pm ]
Post subject:  Cyber Commander V1 won't accept Firmware update
I have a Cyber Commander (without external antenna).
I am trying to load the Firmware update and all it does is flash a white screen then shows the current Version number and turns on the Einsteins I have set up at the moment and goes to the home screen.
I've tried two micro cards, formatted one in the CC and another with Windows 7. All to no avail.
Author:  Technical Support [ Fri Aug 05, 2011 4:52 pm ]
Post subject:  Re: Cyber Commander V1 won't accept Firmware update
I assume these are MicroSD cards of 2GB or less? Also, when formatted in the PC, it was formatted to FAT (as opposed to FAT32)? Which firmware are you upgrading from?
Author:  dmward [ Fri Aug 05, 2011 5:01 pm ]
Yes, One Micro is the one that came in the CC, the other is 2G I bought with a phone.
Not sure what CC formats to but Win 7 does FAT with is FAT16 since they offer FAT32 as an option.
Current V is 32.
Author:  Technical Support [ Mon Aug 08, 2011 10:03 am ]
If you have not done so, try reformatting the cards (in the computer), and attempt the update again. If this fails, you may want to call in, as the nature of the update would drag for ever via the forum.
