| Reflector for PLM? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1676 |
Page 1 of 2 |
| Author: | Pultzar [ Fri Aug 05, 2011 5:40 pm ] |
| Post subject: | Reflector for PLM? |
Is there a recommended reflector for use with a PLM to eliminate the spill to the sides? I'm using the speedring configuration so it would need to be compatible with that if possible. |
| Author: | ltwimberly [ Sat Aug 06, 2011 10:27 am ] |
| Post subject: | Re: Reflector for PLM? |
The PCB umbrella reflector is meant to block spill to the sides. You can't mount a reflector and a speedring at the same time though. You'd need to mount the PLM using the umbrella bracket on top and mount the reflector using the fingers. |
| Author: | BDP [ Sat Aug 06, 2011 2:26 pm ] |
If you are mounting a PLM to an AB, Einstein, etc, using the mounting ring option provided with the PLM, and properly positioning the umbrella shaft (the thumbscrew should go into the hole on the sliding shaft), you should have little or no spill at all. If you are getting a lot of spill to the sides, you may not be mounting the light deep enough into the umbrella. The provided mount is set up to properly position it, but also to allow you to move the light out of the focus point of the parabola, if you don't want the column of light effect. I set mine up when I first got it, put it near a wall, with the light directed parallel to the wall (not at it) and there was almost no light hitting the wall at all. There are some reflections off the "tripod" on the speed ring, but only a small amount. |
| Author: | ishootchairs [ Sat Aug 06, 2011 4:23 pm ] |
Quote: I set mine up when I first got it, put it near a wall, with the light directed parallel to the wall (not at it) and there was almost no light hitting the wall at all. There are some reflections off the "tripod" on the speed ring, but only a small amount. I can vouch for this... I used softboxes and when I switched to 86" and 64" PLM's I was also concerned about spill but it turned out to not be an issue. |
| Author: | Deafy Dad [ Sat Aug 06, 2011 5:26 pm ] |
What Is light spill? I'm relatively new, I want learn and tismforum isma good start |
| Author: | Pultzar [ Sat Aug 06, 2011 6:08 pm ] |
Thanks! I'll check my mounting position. |
| Author: | PowerEngineer [ Sat Aug 06, 2011 6:59 pm ] |
Deafy Dad wrote: What Is light spill? I'm relatively new, I want learn and tismforum isma good start In this case, spill is "raw" light that is not hitting the modifier. Instead, it is coming from the flash tube and going straight out into the world. The optimal mounting point for a PLM is to have the flash tube even with the PLM edge. If the flash tube is further out then some of the light can miss the modifier and spill out. |
| Author: | Deafy Dad [ Sat Aug 06, 2011 7:29 pm ] |
PowerEngineer wrote: Deafy Dad wrote: What Is light spill? I'm relatively new, I want learn and tismforum isma good start In this case, spill is "raw" light that is not hitting the modifier. Instead, it is coming from the flash tube and going straight out into the world. The optimal mounting point for a PLM is to have the flash tube even with the PLM edge. If the flash tube is further out then some of the light can miss the modifier and spill out. Thank u for your time. Is there any way we can talk on instant message. Anyone can Im me Deafy dad. Yahoo messenger I want make new photog friends and learn few new simple tricks... I need few help! Thank you pcb community |
| Author: | PowerEngineer [ Sat Aug 06, 2011 8:35 pm ] |
Deafy Dad wrote: PowerEngineer wrote: Deafy Dad wrote: What Is light spill? I'm relatively new, I want learn and tismforum isma good start In this case, spill is "raw" light that is not hitting the modifier. Instead, it is coming from the flash tube and going straight out into the world. The optimal mounting point for a PLM is to have the flash tube even with the PLM edge. If the flash tube is further out then some of the light can miss the modifier and spill out. Thank u for your time. Is there any way we can talk on instant message. Anyone can Im me Deafy dad. Yahoo messenger I want make new photog friends and learn few new simple tricks... I need few help! Thank you pcb community DD - I'd be happy to chat with you more and share what I know. The easiest way for me would be via e-mail. You can e-mail me through my website which you can find in my profile on here (just click on my name over to the left). |
| Author: | Luap [ Sat Aug 06, 2011 9:38 pm ] |
7UR Here: http://www.paulcbuff.com/reflectors.php |
