New PLM™s available for order now. Comparison photos
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1683
Page 1 of 6
Author:  Luap [ Mon Aug 08, 2011 8:09 pm ]
Post subject:  New PLM™s available for order now. Comparison photos
All new PLM™ versions are now online, including the new Soft Silver and straight 8mm shaft versions. http://www.paulcbuff.com/plm.php
http://www.paulcbuff.com/plm-status.php
Note detailed comparisons, pattern shots, color temperatures, output and coverage specs and comparisons to knockoff brands. http://www.paulcbuff.com/plm-competitor.php http://www.paulcbuff.com/plm-softsilver.php
Author:  Deafy Dad [ Mon Aug 08, 2011 10:07 pm ]
Post subject:  Re: New PLM™s available for order now. Comparison photos
so it is better than softbox?
Author:  BDP [ Mon Aug 08, 2011 11:03 pm ]
Order placed for 1 of each!! I'm going to wait on the porch now :ugeek:
Author:  Luap [ Tue Aug 09, 2011 12:29 am ]
For some uses, yes, for other uses, no. Easier to use and setup, and cheaper, but it not as "clean" from the front for wine bottle and silverware, etc, because it has the light in the center of it. I would probably use Soft Silver with or without front diffuser for most work, especially people.
Author:  kenyee [ Tue Aug 09, 2011 8:45 am ]
Looks great!
btw, on shipping the speedring version, are you guys locking down the extension shaft before shipping now? When I got my PLMs, the extension shaft was bouncing around loose and scuffing up the interior...
p.s., thanks for holding back on the announcement until you were sure they'd be shipping on time...
Author:  Luap [ Tue Aug 09, 2011 11:03 am ]
The speedring version can be assembled in various ways, therefore the tubes are not locked into a particular configuration. There are assembly instructions for the various configurations. Ww realize people don't like to read instructions, but sometimes it helps.
I agree about the lack of protecting the rods from bouncing around and getting scratched up, and we will address this.
Author:  kenyee [ Tue Aug 09, 2011 1:01 pm ]
Thanks Paul :D
Author:  CanadianEh [ Wed Aug 10, 2011 12:05 am ]
Were the comparison shots (the ones of the light shooting into the PLM) done using the speedring version?
Author:  Luap [ Wed Aug 10, 2011 2:22 am ]
No, they were all done with the 8mm straight shaft versions. All were 86". 64" and 51" produce essentially identical patterns and output. The camera was positioned such that the light struck the lens dead center.
Author:  Deafy Dad [ Wed Aug 10, 2011 9:01 am ]
Can u explain difference between 7mm amd 8mm
Is it thickness of material or relating to light?
Page 1 of 6 All times are UTC - 6 hours [ DST ]
