Einstiens and the Sekonic L-758DR
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1698
Page 1 of 2
Author:  ralphduke [ Sun Aug 14, 2011 11:31 am ]
Post subject:  Einstiens and the Sekonic L-758DR
I'm thinking about purchasing the Sekonic L-758DR, will this meter trigger my Einsteins and my cybersync?
I know they work with the pocket wizards, but, Im using the Buff cybersync with the commander.
Ralph Duke
www.ralphduke.com
Author:  Photodan [ Sun Aug 14, 2011 9:03 pm ]
Post subject:  Re: Einstiens and the Sekonic L-758DR
Nope, pocket wizard uses a frequentcy that is their own. PW does sell a receiver made for the Einstein but if you already own Buff stuff, that may be redundant.
Author:  Technical Support [ Mon Aug 15, 2011 9:35 am ]
Well, It will not trigger with the module that does into the meter. Those are only PW compatible. You can connect a sync cord from the meter to a light or from the meter to a CyberSync Transmitter (my prefered method, if not using Cyber Commander). Also, you can use the "cordless" option of the meter. This has you "arm" the meter, then you would press the test button of a CST. The meter senses the flash firing and meters them then. It is more simple than it sounds when spelled out. This is Paul's prefered method when not using Cyber Commander.
Author:  derekchinese [ Tue Aug 16, 2011 2:20 pm ]
I also think it works great if you just connect a CST to an extra pocketwizard
1.) L758 triggers the pocketwizard
2.) pocketwizard receiver triggers the CST
3.) The CST triggers your lights
I've done this and it works great
Author:  ralphduke [ Thu Aug 18, 2011 10:25 am ]
AHHHH great idea!!!!
Thank you!!
Author:  ralphduke [ Tue Aug 23, 2011 12:25 pm ]
worked perfectly!!!
Thank you
Ralph
Author:  cas5 [ Fri Aug 26, 2011 7:26 pm ]
Are there any plans to create a module to trigger einsteins from Sekonic light meters? They did create a PW module for Einstein.
Author:  Technical Support [ Fri Aug 26, 2011 8:58 pm ]
There are no plans I am aware of. If we make a module to work with another company's product, we are at the mercy of that company to not pull any proverbial rugs out from under us. Paul prefers to innovate product over keeping up with maintaining compatability with others' products.
Author:  Luap [ Sat Aug 27, 2011 12:16 pm ]
The PW MC2 module will allow direct triggering of Einstein from all PW sources.
http://www.paulcbuff.com/mc2.php
Author:  dphotoman [ Sun Aug 28, 2011 3:54 pm ]
What Paul say s is true you can trigger the E-640's with the PW- MC2 with the L0758DR but only if you set the MC2 to receive on a standard channel if you are hoping to use a control TL channel it will NOT trigger the strobe. If you want to use the Control TL you have to set the meter to read flash the trigger the meter then you have 90 seconds to trigger the strobes with the camera to get a reading.
