Problem with my Vagabound Mini
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1710
Author:  Black&White [ Sat Aug 20, 2011 5:06 pm ]
Post subject:  Problem with my Vagabound Mini
I used today my Vagabound Mini for first time, I connected 4 Elinchrom RX600. After 10 shots in full power, the flashes stop firing. The three battery lights are on, but the Vagabound don´t give power, I try with another flashes but it didn´t work. What´s the problem? (Sorry for my english)
Hoy usé mi Vagabound Mini por primera vez, le conecté 4 Elinchrom RX600. Despues de 10 disparos a maxima potencia, los flashes dejaron de disparar. Las tres luces del indicador de la bateria estan encendidas pero el Vagabound no entrega potencia, probé con otros flashes y tampoco funciona. Cual puede ser el problema?
Author:  Ziv [ Sat Aug 20, 2011 7:23 pm ]
Post subject:  Re: Problem with my Vagabound Mini
4x600ws with 10 quick pops... check the fuse. Just my guess.
Author:  Luap [ Sun Aug 21, 2011 2:43 am ]
10 2400WS pops in rapid succession? You probably overheated the inverter and it probably shut down for thermal protection. If does a thermal shutdown it will come back on in a few minutes.
Not likely the fuse. If the fuse blew the battery lights would go out. If the inverter actually failed it would be extremely rare . . . we've probably had about three out of 6000 actually fail. These things are extremely reliable.
