Sun Aug 21, 2011 11:27 am
Since i only have 2 einsteins at the moment, I think I recall that the older versions of the cybercommander allowed you to save power settings while in the group mode. So say for example in group 8, I wanted to have light 1 (L1) and L2 to be at 1/1 power and 1/2 power respectively. If i thumb over to group 7, is it possible to have those power settings saved as well as the lights that are in the group? Group 7 would be the flipped lighting ratio of 1/2 and 1/1 power respectively or group 6 could be 1/4 power and 1/256 power. Essentially is there a way to store the light settings per group? that would make the cybercommander more useful for storing light settings.
I believe the other way of doing what I'm trying to describe is to open memory but that adds several thumb clicks and there is a slight delay when opening the memory. Trying to save 8-15 seconds of navigating the cybercommander menu.
Sun Aug 21, 2011 1:10 pm
No. Any one light's setting cannot change simply by changing groups. Groups are designed to include or exclude lights at thier current settings. To do as you describe, you would need to change save locations.
To expedite this, start your save locations at SD50, and work backwards. This will negate the need to scroll through CH1-CH16 before getting to the SD locations.
If you scroll left once, you will go directly to SETUP. If OPEN MEMORY was the last screen used, it will already be highlighted. Also, once any changes are made, press refresh on the right j/s to ensure all lights recieved the signal.
If it is imperative that changes be made as rapidly as possible, it is possible to use two (or more) Cyber Commanders with different set ups, and use the refresh command to switch between them.
Users browsing this forum: Majestic-12 [Bot] and 15 guests
