Cybercommander Flashmeter ISO
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1716
Author:  BigIronCruiser [ Mon Aug 22, 2011 9:00 am ]
Post subject:  Cybercommander Flashmeter ISO
Is there a way to change the CyberCommander's default ISO value in such that it remains persistent while changing batteries? If not, then can it be saved to an SD card?
Author:  Technical Support [ Mon Aug 22, 2011 10:15 am ]
Post subject:  Re: Cybercommander Flashmeter ISO
ISO will revert to 100 when power is lost. Also, this is not a function that is saved as part of a set up. However, you can offset ISO with CAL (in the same screen). CAL can be saved as part of a set up.
Author:  BigIronCruiser [ Mon Aug 22, 2011 1:15 pm ]
What are the odds of adding this in a near-term firmware update?
Author:  Technical Support [ Mon Aug 22, 2011 2:30 pm ]
I can't give odds. Too far out of my control. However, your suggestion has been noted.
Author:  BigIronCruiser [ Mon Aug 22, 2011 3:24 pm ]
Thanks. IMO, it would be best to make ISO a "sticky" setting, such that it would always revert to the most recent setting following a hard power reset.
