Vagabond Mini only firing 10-12 times
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1717
Author:  darcytdog [ Tue Aug 23, 2011 7:08 pm ]
Post subject:  Vagabond Mini only firing 10-12 times
I used my Vagabond Mini today for its first extended use. I had a Dynalite 1000ws set at only 250WS and was using Pocket Wizard transmitters. After firing the flash 10-12 times I could no longer trigger it remotely but could fire by pressing the test button on the pack. I stopped using the mini for about an hour and used it in a different scene, this time at 500 ws. It fired about 3-4 times and stopped as before. The battery had been freshly charged the night before. Any ideas?
Author:  Technical Support [ Tue Aug 23, 2011 10:45 pm ]
Post subject:  Re: Vagabond Mini only firing 10-12 times
Are the pocket wizards built into the pack? If so, the processors to the recievers could be crashing during the power drop.
Author:  darcytdog [ Wed Aug 24, 2011 2:26 pm ]
The Dynalite did have a built-in Wizard. Will try with external unit, Thanks!
