| want to buy b1600's but... http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1737 |
| Author: | sofresh [ Sat Sep 03, 2011 8:20 pm ] |
| Post subject: | want to buy b1600's but... |
i would like to know if i can fire them using calumet pro series slaves. I read the manual and it reads it comes with a 15ft. sync cord that plugs into the camera but i wanna go wireless to fire 2 sb1600's and one sb700 nikon speed light. any info would help very much. thank you. |
| Author: | Luap [ Sat Sep 03, 2011 9:50 pm ] |
| Post subject: | Re: want to buy b1600's but... |
Should work OK as long as the receivers can connect to the ABs with a 1/8" mono earphone plug. Indoors, you can probably fire them OK with one receiver on the SB via ABs optical slaves, but the SB will have to be on manual and have no preflash signal. |
| Author: | sofresh [ Sun Sep 04, 2011 12:32 pm ] |
Luap wrote: Should work OK as long as the receivers can connect to the ABs with a 1/8" mono earphone plug. Indoors, you can probably fire them OK with one receiver on the SB via ABs optical slaves, but the SB will have to be on manual and have no preflash signal. you thank you for your response. i will be ordering them right now. |
