Alienbees on Mini Vagabond and Radipopper JRX problem
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1738
Author:  Jiri [ Sun Sep 04, 2011 1:10 am ]
Post subject:  Alienbees on Mini Vagabond and Radipopper JRX problem
Hi All
>I have recently bought from Paul C Buff australia 2x Alien Bees B1600.
>Here is the problem I have.
>If the B1600 are connected to mains power and radiopopper JRX transmitter is
>connected to sync and remote slots, everything working great, firing,
>powering down/up, modeling lamp down/up right from the Radiopopper JRX
>studio transmitter. But when I connect the B1600 to Mini Vagabond pack and
>have the JRX receiver plugged the same way as when its connect to mains, the
>B1600 keeps flashing and I cannot trigger it with radiopopper at all. Only
>works when I disconnect the JRX transmitter from REMOTE slot and leave it
>connected to SYNC only. That way it works but I have to keep coming to B1600
>to manualy power them down or up with the slider at the back of the unit.
>I am not using the B1600 as modeling lamp when they are on battery pack but
>only as strobes.
>What am I doing wrong?
>Thanks heaps
Author:  ltwimberly [ Sun Sep 04, 2011 7:48 am ]
Post subject:  Re: Alienbees on Mini Vagabond and Radipopper JRX problem
Try connecting the JRX to the REMOTE slot only. Plug one end of the 1/8" cord into the SYNC port on the Bee, but don't plug the other end of it into the JRX. This is called a "dummy plug" and it disables the Bee's slave eye. I haven't used Radio Poppers but this is the correct way to connect PCB's CSR+. With the CSR+ the signal to fire the flash is sent through the REMOTE port and the SYNC port - but only one or the other should be connected to a strobe at the time. I presume that this would be true for the JRX also.
Author:  kenyee [ Mon Sep 05, 2011 9:42 pm ]
Do you have another JrX receiver?
How did you get those down in Australia? I thought they didn't release non-US ones yet?
Author:  Technical Support [ Tue Sep 06, 2011 9:55 am ]
Try using the Model=Off on the light and Model=On in the RP. Otherwise, this is a question for Radio Popper.
