Vagabond mini VAC
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1742
Author:  tville59 [ Mon Sep 05, 2011 3:59 am ]
Post subject:  Vagabond mini VAC
Hi
I am considering the Vagabond mini. I was wondering which to get, the 120VAC or the 230VAc.
I live in Queensland
Author:  marokero [ Mon Sep 05, 2011 7:51 am ]
Post subject:  Re: Vagabond mini VAC
Australia uses 240v if I'm not mistaken, so you should get the 230v VML.
Author:  krisblucher [ Mon Sep 05, 2011 7:58 am ]
The volts you refer to is the output volts. That must match the lights input voltage requirements.
What lights are you using (Make/model/voltage).
You can charge it anywhere in the world (input to VML is 90-240 ish)
Author:  marokero [ Mon Sep 05, 2011 8:10 am ]
krisblucher is correct. My brain wasn't firing at all cylinders when I posted earlier. I should refrain from posting right after waking up :p
