| Use of Vagabond Mini while plugged in (charging)? http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1756 |
| Author: | amoringello [ Sat Sep 10, 2011 5:29 am ] |
| Post subject: | Use of Vagabond Mini while plugged in (charging)? |
Is it safe to leave the Vagabond Mini's plugged in (charging) while being used? Lets say if someone was just too lazy or not thinking and left them charging while doing a shoot in the studio? |
| Author: | BDP [ Sat Sep 10, 2011 3:30 pm ] |
| Post subject: | Re: Use of Vagabond Mini while plugged in (charging)? |
I believe the answer is yes, and I think that may be documented on the site, either in the web page for the mini, or in the manual |
| Author: | Technical Support [ Sat Sep 10, 2011 5:51 pm ] |
Its safe. If you are that close to AC power, I dont know why you would use the VML (unless the AC source is questionable). |
| Author: | amoringello [ Sat Sep 10, 2011 5:56 pm ] |
Technical Support wrote: Its safe. If you are that close to AC power, I dont know why you would use the VML (unless the AC source is questionable). Nah, just not thinking. I just got them and have been running some tests with the VMLs before I take them into the field. I left them on the stand when I was done, plugged in the charger, and the next day I just turned them on without disconnecting the charging unit. Thanks. |
