Thu Dec 01, 2011 4:49 pm
I have two vagabond mini's bought at different periods in time. The first one seems to be of less quality than the second, especially in the feeling of the charger. On the charger of the first one, the red / green lights blink back and forth constantly while charging. On the new charger it just stays red until it is charged, then switches to green.
Is it normal for the first charger to switch light colors like that? Or does that indicate some sort of error? By the time it is finished charging it does switch to green solid light.
Thanks.
Fri Dec 02, 2011 12:02 pm
If the style of charger that is blinking has a rectangular LED, then the charger should be replaced. If the LED is circular, then that is not neccessarily abnormal, but may be the order in which everything was connected.
Fri Dec 02, 2011 2:04 pm
It is rectangular. How can I go about getting it replaced?
Fri Dec 02, 2011 2:34 pm
You can call customer service at 1-800-443-5542 or email them at info@paulcbuff.com and they will get you taken care of ASAP!
Users browsing this forum: No registered users and 20 guests
