Fri Apr 25, 2014 8:34 am
My vagabonds are about 2 years old. They have seen reasonable use but wondering if there is a specific time I should look to replace the batteries?
Fri Apr 25, 2014 8:59 am
If it is the Vagabond Mini Lithium, then you can expect to replace the batteries anywhere between 1-3 years, depending on usage.
Fri Apr 25, 2014 10:38 am
yes it is, thanks. I'm guessing I can get through 'til winter before replacing mine. When it fails is it a gradual or steep drop off in charge holding capacity?
Fri Apr 25, 2014 4:31 pm
First, for the purposes of "shelf life", "end of life" would be defined as a 30% reduction is capacity vs a new battery. This would be a gradual reduction in capacity.
Sat Apr 26, 2014 12:51 am
We don't have exact data on this, because it takes three years of testing to find out.
Haven't had a whole lot of battery replacements yet, so it looks like the majority are lasting over three years.
I suspect after falling to 70% they will start dropping at an accelerated rate.
Users browsing this forum: No registered users and 12 guests
