Fri Sep 16, 2011 7:59 pm
Received new Einsteins. Fired the flash for testing approx. 30 times during set-up. Now the LCD panel is lighted and all other functions are working properly but the flash will not test fire. I have restarted, etc. Any ideas except that I got a bad tube?
Fri Sep 16, 2011 11:17 pm
There's a thermal shut-down feature. If they were very rapid, full/near-full power flashes then the unit may have overheated. You can always let it cool off for a while and then try again. It's also possible that the bulb isn't seated well.
If you want to troubleshoot you could swap flash bulbs between your Einsteins. Don't touch the tubes directly - use a clean cotton cloth to handle them. By swapping them you can tell if the problem is the bulb or the Einstein itself.
Sat Sep 17, 2011 10:14 am
I tried that and it did flash so I guess that I will contact PCB Thanks
Mon Sep 19, 2011 8:48 am
If the unit does not start firing after a cooling period, please contact us for warranty service options.
Mon Oct 03, 2011 8:40 pm
Tried one of the other flash tubes and still didn't work. Contacted PCB and they sent me a new unit within 2 days. Thanks for great service.
