Power MC-2 Pocket Wizard using my Sb-900 as Zone Controler
http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1825
Author:  matrixphoto [ Mon Oct 03, 2011 2:12 pm ]
Post subject:  Power MC-2 Pocket Wizard using my Sb-900 as Zone Controler
Hi I have 2 Einstein Units and recently purchased the Pocket wizard FLEX TT5 for nikon if i purchase the MC-2 Pocket Wizard for Einstein can I use one of my SB-900 as the Zone controller instead of the pocket wizard AC-3.
Lou Recine
Author:  Technical Support [ Mon Oct 03, 2011 2:59 pm ]
Post subject:  Re: Power MC-2 Pocket Wizard using my Sb-900 as Zone Controler
This would be a function or limitation of the TT5 and/or SB900 combination. Paul C. Buff, Inc. is not familiar with those products well enough to advise you on that question.
You can contact Pocket Wizard at info@pocketwizard.com or if anyone knows the answer, they are certainly welcome to respond.
Author:  BigIronCruiser [ Mon Oct 03, 2011 9:50 pm ]
The answer is yes, although I believe you would be happier with an AC-3. Also, keeP in mind that you need an MC2 for each Einstein.
