| Questions on original Vagabond http://paulcbuff-techforum.com/viewtopic.php?f=8&t=1843 |
| Author: | munzzzzzzz [ Mon Oct 10, 2011 12:43 pm ] |
| Post subject: | Questions on original Vagabond |
I have a couple quick questions on the original Vagabond 1: 1) I know the manual says that the grounding rod is necessary - is that still the case? I ask only because newer systems (i.e. VML) don't seem to need one and I'm wondering if that is due to a different design or if the risk was determined to be small enough that it just wasn't necessary. 2) Do you by chance have the dimensions of the battery handy? I would like to see if I can find a replacement locally to avoid shipping charges but don't have mine available right now. Thanks! |
| Author: | Technical Support [ Mon Oct 10, 2011 4:20 pm ] |
| Post subject: | Re: Questions on original Vagabond |
It is not really necessary. If you are in a really high RF environment, then you will want to, but in normal usage, you can forego the grounding rod. The demensions of the battery are below 15cmW x 9cmD x 9.5cmH |
